"Open Container folder in New XnView"
brotondi
Post by brotondi »
... would help to have a look at the folder without loosing the search results
-> Or save the Search Results to
a) go back via "Back Button" or by Typing "<Search results>" in the Address Bar...
b) jump from container folder to container folder (or search result to search result, but if you have 200 Results each folder it would help to jump to the next container)
Workaround: Use MS Explorer
Greetings, Bruno
marsh
Post by marsh »
brotondi wrote:... would help to have a look at the folder without loosing the search results
I found similar request for rememberinglast used<search results>.
