big trouble with printing: doesn't set orientation for print
andreasm82
Post by andreasm82 »
steps to reproduce:
go to file -> print setup
enter settings of your printer
select Landscape Format and click ok, close print-setup
select an image and go to file -> print
select Portait or Landscape under Orientation
-> The print preview looks very very bad!
Take a look at this screenshot. In background, there's the real picture.
In preview there are some strange red dots....
It also doesn't recognize the aspect-ratio.
But: In general, the print preview looks always a little bit strange...there are colors which aren't in the pictures...
This preview was much better in older xnview versions.
At the moment, I can't use print-function in cause of these strange bugs...
Re: big trouble with printing: doesn't set orientation for p
andreasm82 wrote:steps to reproduce:
Yes a known issue if oyu change orientation in printer setting, not in print dialog
