Win key exits full screen mode
joximus
Win key exits full screen mode. Is this intentional (I think not). I use Win key in many of my hotkeys. Can you disable it (Esc key is enough for exiting full screen) or at least have an option to change it.
Re: Win key exits full screen mode.
Hmm, think the initial idea was that any key should bring the user back to normal screen mode.joximus wrote:Win key exits full screen mode. Is this intentional (I think not). I use Win key in many of my hotkeys. Can you disable it (Esc key is enough for exiting full screen) or at least have an option to change it.
But I agree: The modifier keys ('Win', 'Alt', 'Ctrl' and 'Shift') should only have a meaning in combination with other keys. When pressed alone, no action should be triggered. So in Fullscreen mode, neither Win key nor Ctrl key should exit the fullscreen mode.
joximus
I think that it is bad idea that any key exits full screen mode. Only one or couple of keys should do so.helmut wrote: Hmm, think the initial idea was that any key should bring the user back to normal screen mode.
Ok, fixed in the next release.joximus wrote:I think that it is bad idea that any key exits full screen mode. Only one or couple of keys should do so.helmut wrote: Hmm, think the initial idea was that any key should bring the user back to normal screen mode.
