It looks like this:
What I like most about it is that you see several results at the same time and you edit by clicking on the thumbnail that looks better. If you're not happy with your current edit, you can always click on Original Picture to reset your edits. It has a quite though through layout since if the picture that you're editing is too red then you can click on the thumbnail which is on the opposite side of the More Red thumbnail.
What i would perhaps like to add to this feature is the ability to edit contrast as well, if there's room for more thumbnails.
regards
Joel
