[XnView ShellExt] Converting with transparency
Crysler
Post by Crysler »
I noticed when converting a transparent PNG the transparency won't stick when converting to GIF. Is it possible to change that?
Re: [XnView ShellExt] Converting with transparency
Crysler wrote:I noticed when converting a transparent PNG the transparency won't stick when converting to GIF. Is it possible to change that?
Your PNG is in 8bits?
Crysler
Post by Crysler »
No, they are in 32bits, like this:
Crysler wrote:No, they are in 32bits, like this:
ok, alpha channel is not converted in 8bits...
