Remember sort order style for each folder...
TsunamiZ
Is it possible to remember sort order style for each folder [like save folder settings]? So each folder can automatically remember its sort style. Thanks.
Hard, but…
—> TsunamiZ
Hello !
• Indeed, sounds interesting, although it seems hard to get at first sight…
• Maybe using a new separate special INI file could help ?
- Anyway, it should need some additional stuff, humm… I will think to this deeply, and will draw something, perhaps …
Kind regards,
Which one ?
- So, I guess that it's much better that a programme doesn't use the Windows' caboodle, as far as possible, this avoids a lot of annoyances and bad surprises…
Just for the fun, the <desktop.ini> files I found out in my XP HD only :
e:\Documents and Settings\CLAUDE\Local Settings\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\desktop.ini
e:\Documents and Settings\CLAUDE\Recent\Desktop.ini
e:\RECYCLER\S-1-5-21-1390067357-308236825-682003330-1003\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\Jeux\desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\Docs_PDF_Henri sur Celeron-xp\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\a2 sur Celeron-xp\Desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\OpenOffice.org 2.0\Desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temp\Historique\History.IE5\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temp\Temporary Internet Files\Content.IE5\3HG2TZ0X\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temp\Temporary Internet Files\Content.IE5\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temp\Temporary Internet Files\Content.IE5\PVY4DSYA\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temp\Temporary Internet Files\Content.IE5\W1SLK767\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temp\Temporary Internet Files\Content.IE5\YWP86HX9\desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\site-multima sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\a-3 sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\cd-romz sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\f4 sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\help-worksho sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\paintbrush16 sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\rambooster sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\system sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\x sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\zip sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\zip-archives sur 166 (Claude33)\Desktop.ini
e:\Documents and Settings\CLAUDE\Voisinage réseau\data sur Celeron-xp\Desktop.ini
e:\Documents and Settings\All Users\Application Data\desktop.ini
e:\Documents and Settings\All Users\Documents\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\desktop.ini
e:\Documents and Settings\CLAUDE\Application Data\desktop.ini
e:\Documents and Settings\CLAUDE\Menu Démarrer\desktop.ini
e:\Documents and Settings\Default User\Application Data\desktop.ini
e:\Documents and Settings\Default User\Local Settings\desktop.ini
e:\Documents and Settings\Default User\Menu Démarrer\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Application Data\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Menu Démarrer\desktop.ini
e:\Documents and Settings\CLAUDE\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
e:\Documents and Settings\CLAUDE\Menu Démarrer\Programmes\desktop.ini
e:\Documents and Settings\CLAUDE\Favoris\Desktop.ini
e:\Documents and Settings\CLAUDE\Mes documents\desktop.ini
e:\Documents and Settings\CLAUDE\Mes documents\Ma musique\Desktop.ini
e:\Documents and Settings\CLAUDE\Mes documents\Mes images\Desktop.ini
e:\Documents and Settings\CLAUDE\Menu Démarrer\Programmes\Accessoires\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Historique\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temporary Internet Files\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\0PM7GDEN\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\8TQNCLU3\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\GD2Z0PQ3\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\OXUB4DYB\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\Accessoires\Outils système\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\Démarrage\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\Outils d'administration\desktop.ini
e:\Documents and Settings\CLAUDE\Menu Démarrer\Programmes\Accessoires\Accessibilité\desktop.ini
e:\Documents and Settings\CLAUDE\Menu Démarrer\Programmes\Accessoires\Divertissement\desktop.ini
e:\Documents and Settings\CLAUDE\Menu Démarrer\Programmes\Démarrage\desktop.ini
e:\Documents and Settings\Default User\Menu Démarrer\Programmes\Accessoires\Accessibilité\desktop.ini
e:\Documents and Settings\Default User\Menu Démarrer\Programmes\Accessoires\desktop.ini
e:\Documents and Settings\Default User\Menu Démarrer\Programmes\Accessoires\Divertissement\desktop.ini
e:\Documents and Settings\Default User\Menu Démarrer\Programmes\Démarrage\desktop.ini
e:\Documents and Settings\Default User\Menu Démarrer\Programmes\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Menu Démarrer\Programmes\Accessoires\Accessibilité\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Menu Démarrer\Programmes\Accessoires\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Menu Démarrer\Programmes\Accessoires\Divertissement\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Menu Démarrer\Programmes\Démarrage\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Menu Démarrer\Programmes\desktop.ini
e:\WINDOWS\Fonts\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Historique\History.IE5\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temporary Internet Files\Content.IE5\71E57MT3\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temporary Internet Files\Content.IE5\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temporary Internet Files\Content.IE5\RED58AYJ\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temporary Internet Files\Content.IE5\TNK4UAKL\desktop.ini
e:\Documents and Settings\CLAUDE\Local Settings\Temporary Internet Files\Content.IE5\V8T42Z0S\desktop.ini
e:\Documents and Settings\Default User\Local Settings\Historique\desktop.ini
e:\Documents and Settings\Default User\Local Settings\Historique\History.IE5\desktop.ini
e:\Documents and Settings\Default User\Local Settings\Temporary Internet Files\Content.IE5\71E57MT3\desktop.ini
e:\Documents and Settings\Default User\Local Settings\Temporary Internet Files\Content.IE5\desktop.ini
e:\Documents and Settings\Default User\Local Settings\Temporary Internet Files\Content.IE5\RED58AYJ\desktop.ini
e:\Documents and Settings\Default User\Local Settings\Temporary Internet Files\Content.IE5\TNK4UAKL\desktop.ini
e:\Documents and Settings\Default User\Local Settings\Temporary Internet Files\Content.IE5\V8T42Z0S\desktop.ini
e:\Documents and Settings\Default User\Local Settings\Temporary Internet Files\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\Historique\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\Historique\History.IE5\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\desktop.ini
e:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\Historique\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\Historique\History.IE5\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files\Content.IE5\71E57MT3\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files\Content.IE5\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files\Content.IE5\RED58AYJ\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files\Content.IE5\TNK4UAKL\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files\Content.IE5\V8T42Z0S\desktop.ini
e:\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\Historique\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\Historique\History.IE5\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\71E57MT3\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\RED58AYJ\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\TNK4UAKL\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\V8T42Z0S\desktop.ini
e:\WINDOWS\system32\config\systemprofile\Local Settings\Temporary Internet Files\desktop.ini
e:\Documents and Settings\CLAUDE\SendTo\desktop.ini
e:\Documents and Settings\Default User\SendTo\desktop.ini
e:\WINDOWS\Downloaded Program Files\desktop.ini
e:\WINDOWS\Offline Web Pages\desktop.ini
e:\WINDOWS\system32\config\systemprofile\SendTo\desktop.ini
e:\Documents and Settings\All Users\Documents\Ma musique\Desktop.ini
e:\Documents and Settings\All Users\Documents\Ma musique\Échantillons de musique\desktop.ini
e:\Documents and Settings\All Users\Documents\Mes images\Desktop.ini
e:\Documents and Settings\All Users\Documents\Mes images\Échantillons d'images\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\Accessoires\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\Accessoires\Communications\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\Accessoires\Accessibilité\desktop.ini
e:\Documents and Settings\All Users\Menu Démarrer\Programmes\Accessoires\Divertissement\desktop.ini
e:\WINDOWS\Tasks\desktop.ini
- I begin to cogitate about this, don't worry !
ckit
How to save these sorting orders ?
• First, I think still that a special INI is required to simplify the thingy… It could be built like :
[Section #1]
DirPath= Path of the directory
SortOrder = Flag
0 : General current default (= non-specified)
1 : Name
2 : Name (numeric)
3 : Extension
4 : Date
5 : EXIF Date
6 : File Type
7 : File Size
8 : Description
9 : Embedded comments; Inverse orders :
–1 : Name (inverse)
–2 : Name (numeric inverse)
–3 : Extension (inverse)
–4 : Date (inverse)
–5 : EXIF Date (inverse)
–6 : File Type (inverse)
–7 : File Size (inverse)
–8 : Description (inverse)
–9 : Embedded comments (inverse);
; Whether anything doesn't match, the “0” default might be applied…
[Section #2]
… and so on for all visited directories…
• Just a start ! Enough for that night
Not at all !
—> ckit
Hi !
• Not sure at all ! And there are only the E:\… HD ones, I've another HD with another WinDung…
• Only those that Total Commander found out !
- Hence, I guess that a standalone system could be better, rather than such a mess !
KR
TsunamiZ
The rest…
• A supplemental menu-entry in the browser from the “Sort by…” button with (if possible) a 3-state tick-box.
- It's shown semi-ticked (grey tick¦lighter greyed background) so using the “Automatic” feature on the small dialogue beside.
- Quite unticked (no tick¦white) should mean that the general sorting order set above in the menu is applied.
- Fully ticked (black tick¦white) should mean that a new order is forced, hence the dialogue'ld appear again at the next change.
• Either the “YES” or the “NO” button might close the box…
• If one should need to display the dialogue again for any reason in the meantime, while the “Automatic” feature is set, it could be possible to create an extra INI entry in <xnview.ini> like :
[SectionXxx…]
SortOrderDialogue = Flag
0 : Not displayed (means that “Automatic” is active still)
1 : The dialogue shall be displayed again when XnView'll be restarted after a manual change here.• Well, now really ended !
- IMHO :TsunamiZ wrote:But since, desktop.ini is used by other file mangers, perhaps it wouldn't hurt to stick to the standard.
1. XnView is not a file manager,
2. Anything as "Standard" sucks for me !
JohnLakkas
boogiepop
Re: Remember sort order style for each folder...
I'm gonna go ahead and bump this 4 years old thread to ask whatever happened to this feature?
+1boogiepop wrote:I'm gonna go ahead and bump this 4 years old thread to ask whatever happened to this feature?
Not sure whether desktop.ini should be used or not. Perhaps the ideal way would be an option to choose whether using desktop.ini or an xnview-desktop.ini.
(I also think this would be a nice feature and support this. A more sophistic way would be a full light table for arbitrary moving images around, there are some topics here in the forum.)
JohnFredC
In MP (not regular XnView, unfortunately), the .xnviewsort file is an ideal container for this (and other) information about how XnView should display and behave in the folder.
( IMO Pierre's decision to use a private XnView MP settings file stored in each folder (currently called .xnviewsort) is a breakthrough for XnView functionality. Potentially very, very useful! )
John
