PixelFusion WMP Plugin 1.50
Pixelfusion is a new technology that enhances digital video, and has taken over 2 years to develop to its current standard. From the start, it was designed so that it could be implemented in software and run in realtime on a home PC, but we also made sure that quality was a high priority.
We noticed that most downloaded or streamed video tend to look 'blurry' due to a reduction in the resolution of the video in order to reduce download time. When viewed, it is usually stretched, or resampled, to a higher resolution. This process is what causes the video to become blurry. Video could be viewed at the original resolution, but it tends to be very small, making it difficult to watch.
The key is in the algorithm which enlarges the video to a reasonable viewing size. Usually, a standard bilinear or bicubic algorithm is performed, which work by interpolating the existing pixels in an image to create more pixels. Because they only perform a simple mathematical interpolation which reproduces smooth transitions from one pixel to another, they will always cause an image to appear more blurry.
Pixelfusion is different, in that it attempts to more accurately predict the pixels that existed in the original high resolution source, to create a much crisper and perceptually clearer image.
Release Notes:
21 Feb 2006 - Version 1.50 released.
* Updated to reflect new version of Pixelfusion technology v1.5. Updated pixelfusion lighting and sharpness algorithm, to better complement 200-300 kbs streaming video content
* Minimum spec machine : 1.0Ghz CPU, 128Mb RAM, 16Mb Graphics Card, Windows Media Player 7.0
* Recommended spec machine : 2Ghz CPU, 256Mb RAM, 32Mb Graphics Card, Windows Media Player 9.0
Download:
http://qolabs.com/pixelfusion/PixelfusionWMP150.exe
Homepage:
PixelFusion WMP Plugin (freeware)
ckit
