Hello does anyone knows how can i remove the conext menu from windows
(when i right click an image)
How to Remove Context menu from windows ?
plouf
Re: How to Remove Context menu from windows ?
Right i must add an option to xnview. In a console use regsrv32 /u XnViewShellExt.dllplouf wrote:Hello does anyone knows how can i remove the conext menu from windows
Dreamer
Yes, hope you mean Shell Extension, option to disable and enable Shell Extension is needed, especially for ZIP version, there is no way to enable it...xnview wrote:Right i must add an option to xnview. In a console use regsrv32 /u XnViewShellExt.dllplouf wrote:Hello does anyone knows how can i remove the conext menu from windows
Workaround is here - Win2k, WinXP.
I'll create a new topic in FAQ soon.
Dreamer
