I search in the forum for this problem but I can't find... So etiher I'm the first to tell it, or have it... or I didn't search well...
Btw, here is the pb :
When I make contact sheets with jpg files, I want to include a number, to identify the picture, so I use the information "Filename Number".
All works well with jpeg's files... but when I use .CR2 (canon 20D raw format), the number is always "2".
I imagine that xnview search a number from the end, in the filename, including extension, and stop when it finds a number.... the fact is that it's a pb with .CR2 files... maybe you should make the search only on filename without searching in extension ?
For sure, it makes me save a lot of time...... and time.... is money :p :p :p
Thanks a lot for all !!!!
"Filename Number" in contact sheet
Re: "Filename Number" in contact sheet
Oh right aElcap wrote:Hi,
Elcap
