I have just recently discovered XnView and it works very well – there is one thing : I'm creating a slide show and wants to burn it to a DVD, but XnView can't find my internal DVD burner drive. Nero is installed and works. Have I do to set any options?
Best regards
Ralf Weber
XnView 1.82.4
Nero 7.0.1.2
Drive : Matshita DVD-RAM UJ-831S
No DVD burner drive found
Re: No DVD burner drive found
No, the problem is Nero API. Perhaps i must update it... I'll checkAnonymous wrote:I have just recently discovered XnView and it works very well – there is one thing : I'm creating a slide show and wants to burn it to a DVD, but XnView can't find my internal DVD burner drive. Nero is installed and works. Have I do to set any options?
Best regards
Ralf Weber
XnView 1.82.4
Nero 7.0.1.2
