Does XnView support Edmics C4?
http://perso.wanadoo.fr/pierre.g/xnview/enformats.html lists it as a supported format but I do not see it supported in your plugins.
Any thoughts?
Thanks
Re: Does XnView support Edmics C4?
Yes, you must enabled option/general/startup/Use all formatsrms wrote:Does XnView support Edmics C4?
Any thoughts?
Thanks
I think this option is really a pain in the a@#. Sounds like: "You have to pull the orange lever under your seat to make your Porsche drive more than 100km/h".xnview wrote:Yes, you must enabled option/general/startup/Use all formatsrms wrote:Does XnView support Edmics C4?
Any thoughts?
Thanks
Sorry for being a bit harsh and rude, but I really see little or no use in this option. Perhaps someone can give some background info why we have this option or point to a topic where this has been discussed.
Not sure, because xnview is more quicker without it, and many users do'tn use it...helmut wrote:I think this option is really a pain in the a@#. Sounds like: "You have to pull the orange lever under your seat to make your Porsche drive more than 100km/h".xnview wrote:Yes, you must enabled option/general/startup/Use all formatsrms wrote:Does XnView support Edmics C4?
Any thoughts?
Thanks
