Images on this page won't open
Rodge
Post by Rodge »
Like a charm…
:) Hello !
- I just downloaded one and I can open it alright in XnView 1.82.4 - Under Win XP-Pro.
- Please, could you explain more precisely which issue you encounter ?
:mrgreen: Kind regards,
I've just downloaded one of the JPGs on the webpage and indeed, it did not open in XnView. I guess those JPG images are stored in a special subformat of JPG.
I'm sure Pierre can tell more about this problem.
Which one ?
—> Helmut
• Hi !
- Like I said above, I downloaded one image : <Train lift2.jpg> so, the first top¦left on the board, and it is displayed in XnView, not any problem…
- I can open it too in "Imagine" as Total Commander plugin (Lister) an in another viewer…
- Please, could you say which image you got ?
:mrgreen: G.
ch3n3
Post by ch3n3 »
Some Thumbnails are Good ("Train lift2.jpg" Image is a Good jpeg ;-) ) but many are not !!!
("WandC locos.jpg" Image (which is the 2nd Thumbnail) is not good (for example)).
:arrow: If you want to see ALL (Bad) jpeg with XnView : "Options" / "Read" > [x]"Ignore Read Errors"...
Good too !
:D Hi !
- Sorry, but I downloaded the second "bad" JPG <WandC locos.jpg>, and it works perfectly here too.
- The option Read >> Ignore read errors is NOT ticked.
{ And aside : I can assure you that my PC is NOT blessed ! :D }
