upper/lower button in options -> write -> pdf interch
andreasm82
Post by andreasm82 »
Go to Options (F12) -> Write -> PDF
select compression JPEG
and click on the upper or lower button of quality. Buttons are interchanged!
This makes no sense if you click on the upper button and the number in the box is getting smaller. :)
BTW: Could you please explain compression methods on that page a little bit more? There's a lot of free space on that page for explanations :)
My private (german) page www.energie-bewusstsein.de
Down is more !
:) Hi !
…Buttons are interchanged!
This makes no sense if you click on the upper button and the number in the box is getting smaller. …
• Right, confirmed !
- Though it's visible only if you set "JPEG" compression, or else, the field ant its buttons are blurred…
- Here, I set rather "ZIP".
:mrgreen: V.G.
andreasm82
It's still not okay :(
