v1.82.4en reading pdf files
Slow Poke
Post by Slow Poke »
there is a truncation issue with the way XnView sees pdf files. The cells
were cut off on the right-hand side. I then made extractions, using ABBY
Fine Reader, of different cell counts to determine if file size made a
difference. XnView read the new pdf files of 01, 02, 05 and 10 okie.
However, when I created the pdf file with 20 cells in it, something
unexpected happened: The files were truncated from top to bottom too.
I'm not sure how to send these files, so I posted it to the alt.binaries.test
newsgroup with the subject header of TEST OF PDF FILES. The Fansadox
file will be the last one posted
using winxp as an OS 512mb ram AMD sempron 954MHz chipset
putt-putt-putt
Re: v1.82.4en reading pdf files
Slow Poke wrote:there is a truncation issue with the way XnView sees pdf files. The cells
putt-putt-putt
You can send me it here [email protected] (remove -nospam)
