Hotkeys to open with various programs...
TsunamiZ
Please allow hotkeys to open images with various programs. So each preset program can have a hotkey assigned to it in the right click menu. This way users don't always have to go find the program in the right click menu to open. Thanks.
Re: Hotkeys to open with various programs...
You have Alt+1, +2 .....TsunamiZ wrote:Please allow hotkeys to open images with various programs. So each preset program can have a hotkey assigned to it in the right click menu. This way users don't always have to go find the program in the right click menu to open. Thanks.
TsunamiZ
Dreamer
I think you have to remove all programs and add them again as you want.Anonymous wrote:So how can I tell which shortcut is for which program without testing them out?
I suggest to add shortcuts next to program in context menu, most users don't even know about them...
E.g.:
PhotoFiltre ... Alt+1
GIMP ............ Alt+2
TsunamiZ
Yes that would be great and save you some tech support work.Dreamer wrote:I think you have to remove all programs and add them again as you want.Anonymous wrote:So how can I tell which shortcut is for which program without testing them out?
E.g.:
TsunamiZ
Dreamer
Dreamer
It's one !
• We can say even that is a
- I just tested adding a programme to open *.ico, and the newest added one is at the top of the sub-menu, like TsunamiZ says.
- Indeed, the shortcuts follow that faulty order…
Dreamer
Dreamer
