Load image from db (ASP)
ddaaddoo
Post by ddaaddoo »
How can I load image from database or from ASP file (like from example2.asp which came in SKD)
I have tried GetBlob and ReceiveBinary, but I am not sure how that methods work!
Re: Load image from db (ASP)
ddaaddoo wrote:How can I load image from database or from ASP file (like from example2.asp which came in SKD)
You want to use it in ASP page?
kikkoma
Post by kikkoma »
try this
set img=Server.CreateObject("GflAx.GflAx")
sql = "select top 1 * from database"
Set rs = nconn.Execute(sql)
rX=rs("image")
rs.Close
img.ReceiveBinary(rX)
response.binarywrite img.SendBinary
I think it will be work!
Jerm
This doesn't work
Post by Jerm »
Your code sample wouldn't work if it could; you can't use parenthesis when calling a sub in asp when using vbscript, so they say.
When I do, in this case though, I get a different error message:
GflAx.GflAx.1 error '80004005'
Unknown format
without the parenthesis,
img.ReceiveBinary rX
it doesn't work either. I get this error:
Bad parameters : 16396
if I change the code to this (as I saw in another post) :
img.ReceiveBinary cstr(rX)
i get this error:
Bad parameters : 8
If I use getblob (as I saw in another post) it gives the same error messages, I assume this is calling the same function internally.
My data is a gif blob from a sql database. other components can read it properly, and if I send it out to the browser (with contenttype and binarywrite) it looks like an image.
any thoughts or ideas?
Jeremy
rozi
Post by rozi »
Try using
rs("image").Value
instead of
rs("image")
and see if it helps.
