Hotkey to bring out favorites menu?
TsunamiZ
Post by TsunamiZ »
Is there a hotkey to bring out the favorites menu? Example: In my web browser, it's ALT+A. Thanks.
Real menus & fake menu
:) Hi !
- AFAIK, nope !
- In the Web browsers, the “Favourites” menu is an item of the menu-bar, hence a short cut can be set.
- In the browser of XnView, this menu doesn't belong to the menu-bar…
• Moreover, only the two upper items you can see displayed are parts of a real menu in the resources of the programme, thus one can set hot keys for them.
- The rest - I mean the dirs to browse - are not menu-items, but entries in an INI file lost somewhere in the Application Data\… …\XnView, and so- named <bookmark.ini>. :|
- This prevents to set hot keys for these entries, and even if you get underlined letters, that doesn't work anyway.
I requested a change of that odd system to Pierre several times yet, unsuccessfully…
- Worse : the <bookmark.ini> values for all versions of XnView you may have in the same partition… At least, a separate file in each version-dir should be desirable, I guess…
:mrgreen: KR
Dreamer
Post by Dreamer »
Maybe it sould be added to menu.
Anyway, hotkey(s) already exist(s) - Ctrl+F1, F6.
