Favorites list pane...
TsunamiZ
Post by TsunamiZ »
Please add a favorites list pane [similar feature found in most web browsers]. So users can have quick access to clicking between favorites. Thanks.
Re: Favorites list pane...
TsunamiZ wrote:Please add a favorites list pane [similar feature found in most web browsers]. So users can have quick access to clicking between favorites. Thanks.
Yes, like Deluxe
TsunamiZ
Post by TsunamiZ »
But Deluxe is so large. It seems it would be slower. I like XnView because it's small. :?
Just added
:) Hello !
- I guess that Pierre meant that this is in DeLuxe, and since it is discontinued, this feature could be added in the normal version, without adding fat too much ;)
• Aside : I've this in my web-browser, and I may admit I never use it ! :P
:mrgreen: KR
TsunamiZ
Post by TsunamiZ »
It becomes useful when there is a need to switch between a lot of favorites frequently. :)
Dreamer
Post by Dreamer »
Clo wrote:• Aside : I've this in my web-browser, and I may admit I never use it ! :P
Same here. :)
I think shortcuts like Alt+1, 2, 3... for Open with would be more useful and quicker, maybe Ctrl+1, 2, 3...?
Hum… French keyboards…
—> Dreamer
:) Indeed short cuts could do the trick, but using digits could lead to land in the issue of the non-US keyboards… like for “Open with…” :|
- Maybe <Insert+ A… B … C… > ? Yes, I know, the Insert key is badly located just beside the Del one…
• The perfect keyboard is to build still…
{ Aside : from some months, a certain «pressure group» tries to promote a come-back to the unique very first alpha layout : ABCDEF… for all keyboards. Why not ? There are no longer levers hooking ones others in our PCs ! }
:mrgreen: KR
Dreamer
Re: Hum… French keyboards…
Post by Dreamer »
Clo wrote:...but using digits could lead to land in the issue of the non-US keyboards… like for “Open with…” :|
I have no problem with Slovak keyboard. Are you sure you don't use right Alt key?
See again---
:) Hi !
- Indeed ! There is not any right Alt key here, it's replaced with AltGr which is an equivalent of Ctrl+Alt
- The digits of the NUMpad are unusable with Alt, and the alpha ones need +Shift here, so, a pain in the neck, moreover, that doesn't work…
:mrgreen: KR
Dreamer
Re: See again---
Post by Dreamer »
Clo wrote::) Hi !
:mrgreen: KR
So it does not work with "left" Alt key? It works here, strange.
