Are favorites saved in xnview.ini file?
TsunamiZ
Are favorites saved in xnview.ini file? If not, where are they stored? Thanks.
ckit
Trust me
• I've already indicated this to you a moment ago here.
- Just searching for the file-name in your PC should give you the full path… which can be else, i.e. under Win 9x :
KR
C:\WINDOWS\Application Data\XnView\bookmark.iniClaude
If you want to know more about the .ini files make sure you read the FAQ "Technical info about XnView's settings (store & load)".
