Search for files with a certain word in file name?
TsunamiZ
Is there a way to search and highlight files in a folder with a certain word in the file name? Thanks.
Classic
- You could try as masks :
word*.*
*word.*
*word*.*
…supposing the word is indeed always the same, and that several extensions can exist for these files…
- I guess that Regular Expressions would allow to perform this as one go, but they are not supported in XnView currently, AFAIK.
STFM !
- You get a dialogue with all needed fields.
You may type the mask(s) in the first upper field for the filename.
- You can see that dialogue in the online Manual HERE
- You can state the directory in wich the search must be performed…
Thumb-nails....
- XnView is not a file-manager, so it can't display lists in panels, at least currently…
