Draging image from viewer into other app?
Tester
Post by Tester »
Is it possible to drag image from viewer as file path into text field in other apps or as an image into graph apps etc.?
Or always I must switch to browser mode before?
Dreamer
Re: Draging image from viewer into other app?
Post by Dreamer »
Tester wrote:Is it possible to drag image from viewer as file path into text field in other apps or as an image into graph apps etc.?
Not possible, but already requested...
Nope
:) ello !
- Outcoming D&D doesn't work anyway from the “View” mode. :|
- This has been requested ¦ discussed several times already, you might use the Search here…
- It works from the the browser, right, for instance from a thumb-nail to the window of another graphic APP.
:mrgreen: Kind regards,
