Nconvert "Set dpi"
Sergey
Nconvert "Set dpi"
Post by Sergey »
I'd like to change the resolution in dpi of Jpeg files obtained by digital camera, but this option doesn't work until I deselect "Keep EXIF data" (Tools-Options-Category-Write-Jpeg). If I deselected "Keep EXIF data" in this case "Set dpi" works well, but I loose the information about Jpeg file (shooting date, aperture, etc.).
Is it possible set dpi and don't loose the file information?
Re: Nconvert "Set dpi"
Sergey wrote:I'd like to change the resolution in dpi of Jpeg files obtained by digital camera, but this option doesn't work until I deselect "Keep EXIF data" (Tools-Options-Category-Write-Jpeg). If I deselected "Keep EXIF data" in this case "Set dpi" works well, but I loose the information about Jpeg file (shooting date, aperture, etc.).
Strange, DPI is not saved in EXIF metadata.
Could you send me an example?
