1.82.4 doesn't open multiple images in external applications
Post by Guest »
I've just updated from 1.82.3 to 1.82.4 and have encontered this little problem:
In context menu "Open with" I've add two application (Photoshop and The Gimp). If i select only one image then I can open it in Photoshop via the context menu, but if I two or more images then appears grey and can't open.
With the older version I didn't have this problem.
I got it on two different computers: one is running Win XP home, the other XP pro, both have SP2 installed.
Thank you
Ciao
Matteo
Re: 1.82.4 doesn't open multiple images in external applicat
Anonymous wrote:Hi,
Yes, i'll fix it
Yes, that's a bug. :bug: See similar topic "Open several files with another program?".
