Yep If you MMB-click an image in the preview area or in the thumbnail-view the M-Key does not work. It only works in fullscreen if you see it in normal-view and then MMB-click it. But not from direct Fullscreen view (F11 as well not)
I'mean its a minor thing but ... a minority to fix I guess
Show Mask - M doesn't work in fullscreen
eweryboooody
Re: Show Mask - M doesn't work in fullscreen
Yes, right i'll add iteweryboooody wrote:Yep If you MMB-click an image in the preview area or in the thumbnail-view the M-Key does not work. It only works in fullscreen if you see it in normal-view and then MMB-click it. But not from direct Fullscreen view (F11 as well not)
eweryboooody
Yes, it's normal because your are not in edit modeeweryboooody wrote:ok. btw: did you recognize that there are even other features that seem to not work that way? Can it be that this view hase not the same key-set or something? eg 'Backspace' for last image does not work either.
Or the rectangle-zoom-feature!!!
I don't know if there is even more...
