GIF comment not shown
CADweazle
Post by CADweazle »
With all my GIFs with comment extension block, the comment will not be shown by ALT+Enter; only when I try to change the comment, it will be shown in the edit dialogue... :(
A bug or not (PNG and TIF comments are shown by the way)??
Greetings, CADweazle
Re: GIF comment not shown
CADweazle wrote:Hi,
Could you send me a sample, please?
CADweazle
Post by CADweazle »
xnview wrote:Could you send me a sample, please?
You've received 2 examples now.
Good luck!
edit:
xnview wrote:From: <!-- removed //-->
Subject: Automatic reply
Due to external projects, i won't be able to read emails during the next few weeks.&#xd; I'll reply asap. Thanks. &#xd; &#xd; &#xd; &#xd;
Öhmmm... to which adress??
Good luck!
Ok, i have it
CADweazle
Post by CADweazle »
any progress??
Got the latest (1.90 alpha2) and I run into the same problem with .PNG-files
Cheers, Carlo
EDIT: Works for PNG, but alpha-channel transparency values are lost during save!!!
CADweazle wrote:Hi,
any progress??
Cheers, Carlo
Sorry, it has been fixed in beta, could you send me again your files?
