Hallo!
I have recieved two pictures.
The name is: "Prästgård.mix" and "klasskort.mix". (swedish)
I think they are created with "Microsoft Picture it"
It is two mix-files.
I could see the pictures in XNView as thumbnails.
When I open the pictures they are exactly the same size as the thumbnails. Very very small. 2x1,5cm.
I want to see them in fullscreen. Is it possible.
If so, how to do!! I do not know how to do.
The files are big. 2,2Mb each.
Is it possible to convert them to another format. JPG?
Best regards
Sören Wallin
Sweden
Open mix-files
Sicky
Open mix-files
Sören Wallin
Sample ???
• Like you can see directly HERE, the MIX format is "Read only" for XnView,
so it's currently impossible to convert it into any other…
- However, it could be displayed as 1:1 scale, that is weird…
- Personally, I've not any file of that format @ home, so it should be great that you place one on a server, with a link here in order to get a sample…
Sicky
Hallo again Clo!!
Thank you very much for your answer!!
Here you have a link to one of my mix-files.
I hope it will work so you can clik on the link and not need to write it. I not sure I done everything right here on "discussion board"
If you can open the file in XNView in fullscreen mood in good quality I will be very glad if you tell me how to do.
If you open it in "Picture it" I think the quality will be perfect. think "Picture It" is a part of "Microsoft Work-Suite"
Hope to here from you again!!
Here you have the link
https://secure.storegate.se/user/Share. ... ren Wallin
Sören Wallin
Sicky
Hallo again Clo!
It did not work!
One more try!
https://secure.storegate.se/user/Share. ... f7527dee4c
Best,
Sören
It did not work!
One more try!
Best,
Sören
Sören Wallin
Guest-rr
Re: Sample ???
Strange, I've always thought that if XnView can read a format, it can save picture in whatever format it supports?Clo wrote:the MIX format is "Read only" for XnView,
