How to show metadata on screen together with picture
Tanitka
Post by Tanitka »
Hi, I am brand new user of this software and the reason i use it is to show metadata info on screen. What i need is to see shutter speed, apperture, focal lenth, white balance.
When i hit "i" button it doesn't shows. I only can see it from properties but it is not comfirtable for comparing pictures.
Could you please help me. I want to know if what i want is possible and how to do it.
Thanks a lot. :)
Re: How to show metadata on screen together with picture
Tanitka wrote:Hi, I am brand new user of this software and the reason i use it is to show metadata info on screen. What i need is to see shutter speed, apperture, focal lenth, white balance.
Thanks a lot. :)
Which value do you used for info?
Dreamer
Post by Dreamer »
Thanks a lot. :)
I think he/she use default setting.
Try Options > View > Fullscreen > [Insert>>]...
Tanitka
Post by Tanitka »
Yes, i use default settings. I tried from menu Edit/Metadata but there i couldn't find out how to show this data as info. I only want to see several items from metadata (sutter speed, apertre, focal lenth, white balance)as "subtitle" together with picture. Now when i hit "i" it only shows the path to the file.
Tanitka
Post by Tanitka »
Sorry, I didn't read Dreamer's suggestion at the end. It works. Thanks a lot for the help.
Dreamer
Post by Dreamer »
You're welcome. :)
