tree view & browser
tomcom
tree view & browser
Post by tomcom »
in the new version i now have a 3 pane view where before i had 2.
the directory/treeview was a narrow left pane & thumbnails were on the right.now i have a small treeview in the top left corner,blank below & the
usual thumbnails on the right 2/3.
i've checked all my settings & still i have this 3 pane in the ass.
tom
Always 3 !
:) Hello !
- In the Browser mode, there are always three panels for ages !
1. The tree
2. The thumb-nails board (if set) or the table showing the content of the current folder etc.
3. The preview area.
- According to the choice you do for the layout of these items, you can get very different looks.
- Please, give a glance HERE, this is shown and explained, then let's know what occurs…
:mrgreen: Kind regards,
tomcom
3 panes
Post by tomcom »
thanks claude, what i needed to do was simply reset the layout in menu "View > Layout" back to the way i always had it. i do think that it's a minor bug when an update changes settings.
thanks for your help!
tom :D
harv
Post by harv »
i got use to opting out of the preview pane in earlier versions. if you de-select the preview pane why have the preview box remain?
harv wrote:i got use to opting out of the preview pane in earlier versions. if you de-select the preview pane why have the preview box remain?
It's a known bug
Post by Guest »
ahhhhh....thanks for response
