XNView doesn't capture tooltips
klumy
Post by klumy »
XNView 1.91.5
Windows XP SP3
marsh
Re: XNView doesn't capture tooltips
Post by marsh »
klumy wrote:XNView doesn't capture tooltips
It works on my win2k. Maybe XP is different though...
ckit
Post by ckit »
Confirmed.
If you use the "Print Screen" key instead of XnView's Capture it captures the toolbar just fine.
loth
Post by loth »
yes. on my XPsp2 no tooltips are captured with a hotkey-capturing, too.
ckits workaround does it.
loth
klumy
Post by klumy »
thanks for the clue.
but what is the reason for that?
XNView 1.91.5
Windows XP SP3
