First step in GFL SDK and AV error
acsrm
Post by acsrm »
Hallo. my name is Robert. Sorry for my english.
I want buy your library in light version, now i tested it with my application and i have problem (
My code:
procedure TFDesktop.Button1Click(Sender: TObject);
  var gfl_bmp: PGFL_BITMAP;
  lp: TGFL_LOAD_PARAMS;
  fi: TGFL_FILE_INFORMATION;
  e: GFL_ERROR;
begin
  gflEnableLZW(GFL_TRUE);
  gflGetDefaultThumbnailParams(lp);
  lp.Flags := GFL_LOAD_SKIP_ALPHA;
  lp.Flags := lp.Flags or GFL_LOAD_PREVIEW_NO_CANVAS_RESIZE;
  e:=gflLoadThumbnail(PAnsiChar('c:\test.jpg',150,150,gfl_bmp,lp,fi); <- this line generate Access Violation error.
end;
File test.jpg exist. I thing that lp.Flags is mayby not corectly ?
What I done wrong ?
I write in Delphi7.
Please help me.
klaus2
Post by klaus2 »
syntax error; i don't know how it could compile:
closing bracket missing after the filename cast; something like:
e := gflLoadThumbnail(PChar(filename), wid, heigh, gfl_bmp, lp, finfo);
acsrm
Post by acsrm »
Hello Klaus2...
Of course I was make a mistake with bracket in example. I write from memory, don't copy from Delphi IDE.
My code compiling without errors.
The problem is still actual.
I have problem with gflBitmapHasEXIF(gfl_bmp) to.
I'm sure that jpeg has EXIF because I read it in other
application i.e. XnView.
In my application gflBitmapHasEXIF always return 0.
For example gflLoadBitmap work correctly.
I work with 2.54 dll.
What's the problem ???
with best regards
Robert
klaus2
Post by klaus2 »
Hello Robert,
don't know, because i don't know your exact code.
The only i can say that the snippet attached works fine
with D4/W9x and D6PE/W2K (i don't have D7).
Maybe your PAnsiChar is the wrong cast.
Best Regards,
klaus2
procedure TForm1.Button1Click(Sender: TObject);
var finfo: TGFL_FILE_INFORMATION;
    e: GFL_ERROR;
    filename : String;
begin
  lp.ColorModel := GFL_BGR;
  lp.LinePadding := 4;
  lp.Flags := lp.Flags or GFL_LOAD_IGNORE_READ_ERROR;
  lp.Flags := lp.Flags or GFL_LOAD_FORCE_COLOR_MODEL;
  filename := GetCurrentDir + '\Image2.jpg';
  e := gflLoadThumbnail(PChar(filename), 40, 40, gfl_bmp, lp, finfo);
end;
Post by Guest »
Hello Klaus2,
I'm shocked. Why ?
Because when I declare:
    e: GFL_ERROR;
    filename:string;
is OK
but when I declare (change position in var declaration)
      e: GFL_ERROR;
      filename:string;
in running program I have AV error.
I see that declaration TGFL_LOAD_PARAMS must be after declaration TGFL_FILE_INFORMATION !
Please test this difference in code. Mayby it's a bug in D7 ?
Thank you for your good intentions
Best Regards,
Robert
klaus2
Post by klaus2 »
Hello Robert,
I can confirm with D4/Win98 i get an AV too after having reordered the var defs in the described way,
I can only imagine it's Delphi (although i never encountered such a prob with Delphi); maybe compiler directives?
After testing, with 2.40 this problem did not occur (however here i have to use gflGetDefaultLoadParams instead of gflGetDefaultThumbnailParams);
However, in a similar context, i remember having had an AV when applying a
e := gflGetFileInformation(PChar(filename), -1, finfo);
before the gflLoadThumbnail call (even if i different receiving variable (finfo2) is used).
Somehow strange, indeed, but its possible ot workaround.
klaus2
acsrm wrote:Hello Klaus2...
with best regards
Robert
Could you send me the jpeg file?
MaierMan
Post by MaierMan »
Never programmed Delphi (at least no serious programming).
I see this declarations in libgfl.pas
type PGFL_FILE_INFORMATION = ^TGFL_FILE_INFORMATION;
  TGFL_FILE_INFORMATION = record
function gflLoadThumbnail(const filename: PChar;
  width, height: GFL_INT32;
  var bitmap: PGFL_BITMAP;
  var params: TGFL_LOAD_PARAMS;
  var info: TGFL_FILE_INFORMATION): GFL_ERROR; stdcall;
while in C it is:
extern GFLEXTERN GFL_ERROR GFLAPI gflLoadThumbnail( const char *filename, GFL_INT32 width, GFL_INT32 height, GFL_BITMAP **bitmap, const GFL_LOAD_PARAMS *params, GFL_FILE_INFORMATION *info );
I'm not quite sure about Delphi stuff, but shouldn't it pass P... types (i.e. the corresponding pointers) to gflLoadThumbnail? (this would surely be true for the other gfl* functions).
At least the C declarations use pointers...
