Bug in JPEG processing (reading no markers after SOS)?
MaierMan
Post by MaierMan »
The "issue" is the following:
After the SOS marker is encountered in a JFIF complicant file no further markers are read.
In not quite sure if it is actually allowed to have markers after SOS section, but I did not find anything (JFIF spec, JPEG spec) thats says no. But I just had a quick glance.
And it seems no problem to read stuff after SOS...
as each 0xFF is considered a new marker except it is escaped with a trailing 0x00. Hence you know when a new section starts even after SOS.
I created a small testfile which is available from:
http://celebnamer.celebworld.ws/stuff/x ... st.SOS.jpg
It has a COM and APP13 (IPTC) section after the SOS section.
This is either a bug or maybe I'm wrong and violate the specs by adding sections after SOS?
Can you clarify this?
