1. Under "Thumbnails" mode, Tools->Set as Wallpaper->Best Fit to Desktop is disable. But Context menu->Set as Wallpaper->Best Fit to Desktop is enabled. Both should be enabled.
2. Under "View" mode, there is a Context menu->Set as Wallpaper item, but not under "Fullscreen" mode. Why? Is it a bug?
Regards,
Nelson
bug about "Set as Wallpaper"
Re: bug about "Set as Wallpaper"
Ok, i'll checkNelson wrote:1. Under "Thumbnails" mode, Tools->Set as Wallpaper->Best Fit to Desktop is disable. But Context menu->Set as Wallpaper->Best Fit to Desktop is enabled. Both should be enabled.
darkfader
I encountered this too.
It was reported before: http://newsgroup.xnview.com/viewtopic.p ... highlight=
So my suggestion would be to allow that command in browser/view mode too if that's an easy thing to add.
I guess it was disabled for a reason but I don't think it's much of a problem anymore to implement it.
