[BUG] Slideshow Transitions, selection impossible +GIF error
Zilexa1
Post by Zilexa1 »
Hi!
I found 2 bugs in the latest version:
It seems XnView has a bunch of transitions for the Slideshow. But you can only select "None", "Cross-fading" and "All Effects".
Why aren't the other effects (used when you select "All Effects") listed?
I am creating a slideshow of 700 Garfields :D I would like to have the 'slide page' effects, Xnview has them when I select All Effects, but then I also get a lot of transitioneffects I don't want.
2nd bug:
for some reason, I cannot have "High Quality" enabled for Slideshows, and use .GIF images, the images appear in black, with a few lines of the image visable.
Also, selecting anything else then "None" for transition effects give the same black result.
(the Garfields are all .GIF images).
Re: [BUG] Slideshow Transitions, selection impossible +GIF e
Zilexa1 wrote:Hi!
On XnView Pocket??? :-)
I'll make the full list
2nd bug:
Which version do you have?
