bug with Excel?
siro
bug with Excel?
Post by siro »
Hello and many thanks for Xnview.
I whish to report an apparently anomalous behaviour of Xnview with Excel.
In my hands the same problem arises with 2 different platforms:
Athlon 3,0 GHz
1G ram
Windows XP
Excel 2003
and
Pentium 4; 1.7 GHz
128 M ram
Windows 2000
Excel 2000
The problem:
When I select and copy a large Excel spreadsheet:
---if I import the clipboard with Xnview version 1.31, all the selected cells are pasted into the image (as expected).
---if I import the clipboard with Xnview version 1.82.4, only the upper left portion of the selection is pasted into the image, approximately 1230 X 1230 pixels.
Is it possible to maintain, in higher versions, the feature available in version 1.31?
Re: bug with Excel?
siro wrote:Hello and many thanks for Xnview.
Athlon 3,0 GHz
1G ram
Windows XP
Excel 2003
and
Pentium 4; 1.7 GHz
128 M ram
Windows 2000
Excel 2000
The problem:
Ok, i'll check the problem
