format .PICT
pi_david
format .PICT
Post by pi_david »
I have a question about how Xnview can support the format .PICT ? I can find in the list of supported format the format .Pictm, but in fact it can't support it with my computer in Windows? Is there something to configure for this support ? Thanks for your attention !!
Read only
:) Hello ! Bonjour,
- This is a Mac format supported by XnView at reading only
- So, please let's know what you wish to do with it.
:mrgreen: Kind regards,
Note : There is a French forum here too…
pi_david
Re: Read only
Post by pi_david »
Je voudrais convertir les images scannées pour un format plus supporté et diminuer la taille du fichier. Quand j'ouvre les images en format .PICT, je ne voix qu'une ligne, rien contenu affiché, mais en fait l'image est bonne sur Mac.
Merci pour votre attention !!
Xiuping
Clo wrote::) Hello ! Bonjour,
Re: Read only
pi_david wrote:Je voudrais convertir les images scannées pour un format plus supporté et diminuer la taille du fichier. Quand j'ouvre les images en format .PICT, je ne voix qu'une ligne, rien contenu affiché, mais en fait l'image est bonne sur Mac.
Xiuping
Could you send me a sample, please?
pi_david
Re: Read only
Post by pi_david »
there is the link of the image for example
http://perso.ecp.fr/~pix/format.html
Re: Read only
pi_david wrote:there is the link of the image for example
Yes, right there is a problem with this file...
pi_david
Re: Read only
Post by pi_david »
I am sur there is no problem with the file because it works with Paint Shop , ImageMagick and with Mac system, however I have no licence for Paint Shop
I doubt the file is corrupt, because I had no problem opening & reading it with these apps:
  • Canvas 9.04
  • Paint Shop Pro 8.10
  • Photo-Paint 11
  • Photoshop 6.01
  • ThumbsPlus 7.0
Gill
pict
Post by Gill »
works with konvertor too
