zoom in for video preview
unbreakable
Post by unbreakable »
the video files in the preview pane do not resize to the maximum size of the preview pane, rather they stay at their original size.
I have gone to the View>Auto Image size > Fit image to window, all
option but this had no effect. I have to press the / shortcut key to preview it zoomed in.
How can I do this...
also how can I define my own shortcut keys? Thanks
Re: zoom in for video prieview
unbreakable wrote:the video files in the preview pane do not resize to the maximum size of the preview pane, rather they stay at their original size.
Video playing is always started in Fit large only
Currently not possible
Dreamer
Post by Dreamer »
unbreakable wrote:...also how can I define my own shortcut keys? Thanks
You can change some actions - Enter, mouse buttons, arrows... in Options.
If you want support Custom Hotkeys/Shortcuts, you can do it here.
pepemosca
Post by pepemosca »
What? Is only fitted if the video is larger than the window area? I mean, is only resized to reduce size?
