req: propper keyboard behaviour (if used under m$ windows)
loth
Post by loth »
hi,
as a keyboardjunkie,
i'd recognized the lack of xnviews compability to m$-windows keys/shortcuts.
just two single simple examples:
a)
-go to browser-mode
-press ALT-ENTER on a thumb. (file properties window will open)
-try to move through the tabs (file/image/exif...) with pressing STRG+TAB
it does not work :-)
the keys STRG+TAB behave like TAB only pressed.
on the other hand, SHIFT+TAB (going backwards) is working.
to confirm this: use m$-explorer, press ALT-ENTER on a file, press STRG+TAB
another example:
b)
-in browser-mode
-press CTRL+D (edit description)
-press TAB. (you'll move with the cursor to the "cancel"-button)
-now, press TAB as long as you like and try to go back to the edit-window, where you can insert text.
now, if you figured out, that it is impossible and pressed ESC, to close the window, follow this:
-in browser-mode
-press ALT-E (go to edit-menu)
-press M twice, or CRSR-UP twice, and then ENTER or CRSR-RIGHT to enter the "metadata" menu. select "set comment..." (while pressing ENTER)
TAB is workin fine in this menu.
unfortunately, the list of windows inside xnview where these "non-uniformities" occoure, is too long to mention.
will this be an issue to fix/make uniform in later versions of xnview?
so i could make a list of windows, but maybe this is a general problem and can be fixed very fast? i really hope so ;-)
EDIT:
if forgot to mention that mouse-issues are covered as well :-)
c)
-go to "batch convert" menu
-double-click on i.e. "Resize Canvas" (right list) to add it to the left list. result: nothing. you have to click the "add"-button.
-(if added via "add"-button) double-click "Resize Canvas" (now in the list on the right) and it will remove it from the list.
loth
loth
Post by loth »
is there any way that we can help with fixing this inconsistent behaviour in consistent one?
i checked my steps to reproduce and it's still the same.
this makes it very unhandy to work with xnview the fast way.
