saving multiple pages
plut0
Post by plut0 »
I have an image file that is a fax with file format .dcx. This file contains multiple images in one file. What I want to do is save the image in another file format, ie. tiff. I can't figure out how to do this.
When the image is open within XnView and I click Save As I get a popup stating:
Be careful, the original image consists of multiple pages, only the current page will be saved.
Do you want to continue and save current page, only?  Ok / Cancel
This will only save one page, not what I want.
I tried from the context menu in Explorer and it does the same thing, only saves one page.
How do I get this to work?
Re: saving multiple pages
plut0 wrote:I have an image file that is a fax with file format .dcx. This file contains multiple images in one file. What I want to do is save the image in another file format, ie. tiff. I can't figure out how to do this.
Use Create/Multi page file
plut0
Post by plut0 »
Ok I got this working but I have a question. When I have a picture open and I click on Create multi-page file, it still asks for the source file. Why? Why would I need to select the source when its already open? Is there an option for this?
plut0 wrote:Ok I got this working but I have a question. When I have a picture open and I click on Create multi-page file, it still asks for the source file. Why? Why would I need to select the source when its already open? Is there an option for this?
Yes, it would be better to open with current file. But i'll add a save mode for all pages of a file...
plut0
Post by plut0 »
If I convert the file from the browser it has the file selected in the source. If I convert the file from the image viewer it does not have the file selected. Can this be changed in the future?
Post by Guest »
xnview wrote:Yes, it would be better to open with current file. But i'll add a save mode for all pages of a file...
Was this fixed ?
