EXIF info. How to create?
Casey44
Post by Casey44 »
I have lots of photo's on my HD. Scanned-in the negatives.
:?::?: Can I create EXIF date-info for them :?::?:
Preferably batch-wise, from the file- or map-name e.g.
Cas
Werner
Re: EXIF info. How to create?
Post by Werner »
Casey44 wrote:I have lots of photo's on my HD. Scanned-in the negatives.
Cas
same problem here - how to create exif fields with scanned images ?
Sorry it's not yet possible to create EXIF
werner
Post by werner »
Thanks for your fast response - is it possible that a new Version of Xnview will support it? - for me it is absolutly satisfactory to use the your dialog in Xnview "change timestamp" - but the creation Date Fields are greyed out
Kind regards Werner
PSHRutPark
Post by PSHRutPark »
Cas
You could try EXIFTool Gui at: http://freeweb.siol.net/hrastni3/. It works very well and is a front end to the excellent ExifTool by Phil Harvey (http://www.sno.phy.queensu.ca/~phil/exiftool/).
I have used it to create EXIF tags for scanned slides.
PETER
werner wrote:Thanks for your fast response - is it possible that a new Version of Xnview will support it? - for me it is absolutly satisfactory to use the your dialog in Xnview "change timestamp" - but the creation Date Fields are greyed out
Yes ican add it, you would like to add EXIF date only?
rra
Post by rra »
Seems like a good idea in general,
that way I can avoid adding EXIF tags with an external program
(e.g. EXifTool) and I can think of a few items:
- image description
- X resolution
- Y resolution
- make (camera or scanner source type)
- date (of creation)
René
ptupper
EXIF date
Post by ptupper »
I too will be looking forward to being able to add EXIF date info to my scans and other pics that have lost the EXIF info along the way.
Additionally, if the EXIF date can be created in batch using the date modified, date entered, or something similar.
Thanks,
Paul
Re: EXIF date
ptupper wrote:I too will be looking forward to being able to add EXIF date info to my scans and other pics that have lost the EXIF info along the way.
So you would like to be able to use 'change timestamp' on exif date even if the file has no exif??
mbrinson
Post by mbrinson »
So was this idea dropped? I'd still like to see this functionality if possible.
Thank you so much for your incredible work with XnView. It is hands down THE BEST free or paid software for viewing images and doing a TON of other things!
lockkopf
Post by lockkopf »
As I see inserting EXIF is still not available in XnView but from my perspective it is very very important.
So far I use a 15 years old otherwise useless Adope Photoshop Album software which offers "Change Date and Time" that automatically inserts EXIF with the three date and time records if missing.
This way is far too complicated because I have to start the programm, click on button Load / From File, select the files, click on button Open, click in menue on Edit /Select All, click in menue on Edit /Change Date and Time, click OK, press Delete key, click OK, close program. :(
After this in XnView I use menue Tools /Change Date and Time to edit proper date and time for every image. So it would be fine if XnView itself would insert EXIF with the three date and time records if missing. :)
lockkopf wrote: After this in XnView I use menue Tools /Change Date and Time to edit proper date and time for every image. So it would be fine if XnView itself would insert EXIF with the three date and time records if missing. :)
Ok, i'll try to add it
lockkopf
Create EXIF Date and Time
Post by lockkopf »
xnview wrote:Ok, i'll try to add it
With 2.12 "insert EXIF with the three date and time records if missing" still is not implemented - any chance doing this?
weiv
Post by weiv »
I was expecting the Change timestamp tool to add exif dates too since it has checkboxes for it. It's rather confusing.
Please make it possible to add exif dates if none exist.
