Problems with SaveBitMap
Gorka
Post by Gorka »
Hiya all,
I am just tryin' out the asp "example4" and I keep on getting this error:
GflAx.GflAx.1 (0x80004005)
Error to create file
The line that is causing the error is: ".SaveBitmap Path & "result.jpg" "
Any ideas what can be going on? Everything else seems to work fine.
This is the code I am using:
' Charge une image, modifie son orientation de 90°, l'enregistre au format JPEG
' et l'affiche dans la page.
' Use a ASP file as source of a <IMG> tag to display a picture in a HTML page
' The following contenttype are available :
' response.contenttype = "image/jpeg"
' response.contenttype = "image/gif"
' response.contenttype = "image/png"
' response.contenttype = "image/bmp"
' response.contenttype = "image/tiff"
' response.contenttype = "image/xpm"
Dim Path, File
Set ctrl = server.createobject("GflAx.GflAx")
Path = "http://pc01/StratMan/StratMan_V0/Pages/"
File = Path & "image.jpg"
const AX_JPEG = 3
With ctrl
.LoadBitmap File
.Rotate 90 'Rotation of 90°
'.SaveFormatName = "jpeg"
.SaveFormat = AX_JPEG 'Save in JPEG format
.SaveJPEGProgressive = True 'Progressive
.SaveJPEGQuality = 70 'Quality of 70%
.Saveformat = AX_JPEG
response.binarywrite .SendBinary
end with
set ctrl=nothing
Thanx a lot in advance !
Thanks a lot !
Gorka.
Re: Problems with SaveBitMap
Gorka wrote:Hiya all,
You must permit writing in the folder...
* Gorka *
Post by * Gorka * »
Hi Pierre,
Thanks for your help.
Folder permissions were already properly set. Actually, I have the OWC writting images to that folder and it works ok from that side.
I tried giving the user "All" full control over the folder, but I still get the same error.
Any other ideas?
aegirth
same problem
Post by aegirth »
I have the same problem..
All permission are right. I can upload the file, but when I try to resize it fails.
"error to create file"
