Pentax *istD RAW File displayed incorrect
Lefty de Vito
Post by Lefty de Vito »
Hello @all,
thanks for providing us with xnview, I'm using it for a long time now.
Last week I came across a RAW-File shot with a Pentax *istD. You can find
it here: http://www.carano.de/sunlion/downloads/IMGP6301.PEF
While version 1.82.2 displays the image correctly, the same file opened
with the current version (1.82.4) shows a purple shift in both the thumbnail
and preview area. This was tested under Windows 2k SP4 and Windows
XP. I cross checked that a few minutes ago with version 1.80.1 running
under Windows XP SP2. The thumb als well, as the preview looks good in
that version. Do you need more information about that?
thx -- Lefty
Re: 1.82.4 - Pentax *istD RAW File displayed incorrect
Lefty de Vito wrote:Hello @all,
Yes, a problem, i'll check...
Lefty de Vito
Thank you
Hi xnview (Pierre),
thank you very much for looking into this. I will forward the information
to the german "Pentax"-Community and the guy who originally detected
that issue.
best regards--Lefty
Lefty de Vito
I just downloaded the Version 1.90 alpha 2 and opened a directory contai-
ning that particular *istD RAW file. The XNView 1.90 alpha 2 displays the
file mentioned above correctly in both the thumbnail and preview area.
thank you very much -- Lefty
