XnView, 2000 and explorer
Post by Guest »
Hi
I cannot open jpg images with xnview from explorer.
I click and nothing seems to happen, but xnview.exe starts to run in task manager.
the only solution was this one.. but with this.. it opens only in full screen mode.
http://newsgroup.xnview.com/viewtopic.p ... ssociation
this is not the association bug. association is correct ending with "%1" and made from xnview association.
any suggestion ?
marsh
Post by marsh »
Try the information in this topic (it sounds similar):
http://newsgroup.xnview.com/viewtopic.php?t=3549
