GflAx not working, security problems?!?
UJN
Post by UJN »
Hey...
Just can't get the examples or any other GflAx code to work and it used to work, here is the error:
Error Type:
Server object, ASP 0177 (0x800401F3)
Invalid class string
/GflAx/exemple1.asp, line 6
And yes I have registered the .dll file... I think it has something to do with security, because I think it started to make errors after I got SP2!
So how do I change the security settings if it's that?
UJN
Post by UJN »
Just made a quick test to see if it was correctly installed.
    On error resume next
    if isObject(Createobject("GflAx.GflAx")) then
        response.write "Is installed."
    else
        response.write "Is not installed."
    end if
Result: "Is Installed."
So what is wrong... Can get any of the examples to work, and as I said - I have used it before but now I just can't get it to work! Please help!
UJN
Post by UJN »
It must be some sort of a security problem...
I'm running Windows XP Professional SP2 with .NET Framework v1.1 installed.
I can't remember if it worked before the .NET was installed!!!
Can somebody tell me what and how to edit security settings?
By the way I'm not running on a NTFS formatted drive just a plain FAT32 if that helps in anyway! I really need some help on this one!
Jean-Pierre
Post by Jean-Pierre »
Do you still have the problem ? :D
I've installed GflAx 2.54 and discovered that the examples are wrong, replace GflAxnnn.GflAx with GflAx.GflAx
Jean-Pierre
