Does XnView support SVG format?
ckit
Re: Does XnView sopport SVG format?
No, it doesn't.Srki wrote:Subject...
You can check here for formats supported:
http://perso.wanadoo.fr/pierre.g/xnview/enformats.html
Right, SVG is not supported, yet. Apart from the "Search" functionality of the forum there's FAQ "Does XnView support graphic format .xyz?" which helps to answer such questions.
