Crop to given size
Brian Pugh
Crop to given size
Post by Brian Pugh »
Is it possible to crop a picture to a given size by giving dimensions? I have some 10 x 15cm photo paper, and try as I might, I can't get a picture to print proportionately on all the paper, ie, edge to edge
Thanks,
Brian
Possible…
:) Good evening, Welcome aboard !
• You could set a custom selection and save it, or use a predefined one -if any is convenient-
¤ Please give a glance HERE.
- Then, apply it to each image (you can move it at the right location…) and crop.
- It's a bit a workaround, but this might work…
:mrgreen: Kind regards,
Brian Pugh
Re: Crop to given size
Many thanks for the welcome, and the information - I will give that a try tonight
Useful pages - are there more?
Brian
big Manual
:) Hello !
- Thanks for this appreciation !
- Indeed you can get the whole Manual HERE and browse its (big) contents from the "Synopsis" client-side image ;)
