XnView Resize Options
sundance
Post by sundance »
First of all, thanks a lot for this outstanding application!
I've been looking for an replacement for ACDSee since they "upgraded" to version 4 and now my search is finally called off: XnView is better, faster and free!
After playing with some of the options and functions I'd like to ask:
  • Is there a way to add/change the resize presets?
  • Can the selection ratio (avail. through Edit | Set selection ratio | A,D) be changed while dragging the selection rectangle? (maybe with pressing some key while dragging)
-sundance-
