Request: gflIsImage function
Alessandro
Post by Alessandro »
to get if a file is an image I currently use gflGetFileInformation() ,
but this function is extremely slow when used over a lot of images, and it seems even slower if the images are big.
Can a function like
 bool gflIsImage(char *filename);
which only looks for magic headers, be added in a future release of gfllib to perform this work at high speed?
Best regards.
MaierMan
Post by MaierMan »
I recommend naming such a thing "gflLikelyImage" or similar, as this is not actually a check but just a hint.
And this fact should be clearly documented.
Otherwise novice GflSDK users will stumple over this for sure.
Re: Request: gflIsImage function
Alessandro wrote:Hi,
Can a function like
Best regards.
gflGetFileInformation is slow??? On which format? This function doesn't read picture...
Post by Guest »
I mainly use png and jpeg files.
it takes about 12 seconds to get if 108 jpegs (about 1300x1000 pixels and about 300kb per image) are images or not.
I let you figure how long it takes to scan a huge set (some thousand) of images, while if i simply use findfirst/findnext the running time is almost inexistent...
Anonymous wrote:I mainly use png and jpeg files.
Strange, gflLoadInformation load only the header of file...
Alessandro
I've never tested how fast files are opened by the OS, the function read() is indeed faster than fread() and that may help to speedup the read of the header (or maybe could be added in gfllib a function which reads only the magic header, that is the first DWORD), but if the opening of files itself is the culprit of this big slowdown maybe I'll have to use the extensions of filenames only.
Thanks for your reply
Alessandro wrote:I've never tested how fast files are opened by the OS, the function read() is indeed faster than fread() and that may help to speedup the read of the header (or maybe could be added in gfllib a function which reads only the magic header, that is the first DWORD), but if the opening of files itself is the culprit of this big slowdown maybe I'll have to use the extensions of filenames only.
For you, in XnView, list view mode is fast? I use the same function...
Alessandro
Using a clock and a listview control (in report mode) they both scored 8 seconds on the above mentioned 108 images
MaierMan
Post by MaierMan »
The speed is quite good here :p
Done a small benchmarking tool (single-threaded).
Available from http://celebnamer.celebworld.ws/stuff/test_gflfi_speed/ (+ Source).
my lil GflSDK getFileInformation() benchmark :p
(C) 2006 Nils Maier - Code subject to BSD-style license
Found 2405 files...
accessing all to fill OS HD cache
benchmarking started
benchmark finished
results
files:            2405
avg.s:          673.25 kb/file
time:       7.83861301 secs
avg.t:      0.00325930 secs/file
Sysinfo
AMD 3800+ X2 - 1.5GB DDR RAM (PC400) - Maxtor 6Y200PO (200GB - IDE) - not-that-much fragmented NTFS
Alessandro
The speed is quite bad here :p
Found 310 files...
benchmark finished
results
files: 310
avg.s: 307.75 kb/file
time: 21.25821382 secs
avg.t: 0.06857488 secs/file
Sysinfo
AMD 2600+ , 1GB DDR 400 , Maxtor 160GB IDE , WinXP
MaierMan
Post by MaierMan »
Alessandro wrote:The speed is quite bad here :p
Sysinfo
Indeed.
files:            1573
avg.s:          491.91 kb/file
time:       7.96920195 secs
avg.t:      0.00506624 secs/file
This benchmark was performed on my system (see above), but on the system partition (part of 2x300GB SATA Maxtor 6L300S0 Raid0)
Another test performed by a buddy. Quite badly fragmented partition.
iles:             666
avg.s:          250.93 kb/file
time:      10.40281861 secs
avg.t:      0.01561985 secs/file
SysInfo: pentium 3.2 GHz, XP Pro, 1 GB DDR ram, Seagate 200GB SATA drive (NTFS).
HD is used heavily by another app the same time.
Quite bad too, but still more than 4x better than your machine.
files:             341
avg.s:          582.02 kb/file
time:       3.24091657 secs
avg.t:      0.00950415 secs/file
Same machine from above, but this time an "idleing" medium fragmented Segate Baracuda 160 IDE HD (NTFS).
But I found somebody with worse results.
files:            2061
avg.s:          539.55 kb/file
time:      60.29231928 secs
avg.t:      0.02925392 secs/file
SysInfo: AMD 64 3200, 2 GIG Ram, 200GB SATA HD, XP Pro SP2
Now this last result is an quite interesting one, isn't it.
I somehow see different AVs as the cause for the performance differences (beside usual stuff as hardware and/or fragmentation).
  • I use AntiVir Personal (with active scanning, but *without* active jpeg scanning.)
  • The first buddy (with the still moderate results) is on PC-Cillin (with active jpeg scanning).
  • And the 2nd buddy (with the worst results) uses Symantec Corp. Edition (with active jpeg scanning).
Conclusion
hmm...
