hi forum
when i browse to a folder that contains svg or hpgl files, xnview chrashes very hard. that means windows explorer do not function properly after that and sometimes i get a bluescreen.
when i change from thumbnail to list view, the effect is the same.
latest xnview on win98
christoph
XNview crashes on svg and hpgl files
Re: XNview crashes on svg and hpgl files
Could you try without CADplugin.dll? And could you send me svg/hpgl sample?chris33 wrote:hi forum
chris33
