LoadFromStream/SaveToStream (Delphi)
Adem
Post by Adem »
I am trying to create a class based on TGraphic but I need a little more info.
Is there a way to emulate LoadFromStream and SaveToStream methods in the SDK?
gflLoadBitmapFromHandle() looks as if it can handle that sort of thing, but I am not sure --nor do I know what each parameter means in real life. Especially the 'handle: GFL_HANDLE'.
Cheers,
Adem
Matthias
Re: LoadFromStream/SaveToStream
Post by Matthias »
I went around this by simply saving the stream to a temp file and then have libgfl load/save the file.
Matthias
Matthias
Re: TGraphic
Post by Matthias »
Do you think about releasing your TGraphic descendant? I would be interested in replacing my own with a better one :)
Matthias
Adem
Post by Adem »
Second question first: Yes, of course I will/would publish it. I dont see any reason why I should keep it private.
Now, the first: I hate using disk for that sort operation. It defeats the whole idea of being a fast lib --all we end up with is a cludge.
Once I get some answer to this loadstream/savestream issue, my next target will be using TSharedImage since TGraphic uses it quite cleverly to speed up Assign().
Cheers,
Adem
Re: LoadFromStream/SaveToStream [Delphi]
Adem wrote:Is there a way to emulate LoadFromStream and SaveToStream methods in the SDK?
Yes, you must use gflLoadBitmapFromHandle. GFL_HANDLE is a pointer of your data. If you know C/C++, there is an example.
Regards. Pierre.
Philips10
gflLoadBitmapFromHandle with Delphi..a few lines of code ple
Post by Philips10 »
Hi Pierre
Could you please give us Delphi-programmers a few lines of code that shows us how to use gflLoadBitmapFromHandle
I got
 ms := tmmorystream.creat
 try
   image1.picture.bitmap.savetostream(ms);
   e := gflLoadBitmapFromHandle( ?? , gfl_bmp, lp, fInfo);
 finally
   ms.free;
 end;
If this is right so far, what to add for the two questionmarks ??
If not at all, please a few lines that shows the use of gflLoadBitmapFromHandle
Thanks and kind Regards
Jansen
