Filetype icon for RAW files
ckv
Post by ckv »
XnView haves filetype icon for RAW, but it is not used. Raw files uses the default filetype icon instead of the raw filetype icon. :|
Re: Filetype icon for RAW files
ckv wrote:XnView haves filetype icon for RAW, but it is not used. Raw files uses the default filetype icon instead of the raw filetype icon. :|
Oh a :bugconfirmed:
